I am restoring an AU-919 and found that I am not able to zero the output of the F2846 Tone board. One channel can be zeroed but the other channel starts with mV of offset then slowly climbs to +20V and the adjustment pot has no effect. The board has been recapped, the 2sc1313 transistors and the zeners were all replaced. I checked all the components, including resistors. I think this is a grounding problem since the output slowly drifts up in value. I cannot get continuity from the F2846 ground traces to chassis ground. Looking at the schematic, the ground path seems to go through several boards and ends up at the driver board, which is then connected to chassis ground. Any advice on what else to check or guidance on the grounding scheme would be much appreciated.
