Sansui au-9500 vs au-8500
afZal
Member
I recently got a sansui au-9500 from my bro.. upon surfing the net i found that the au-8500 has a much bigger value on its caps. the higher model au-9500 has a 4,700uf x4 while the lower model au-8500 house a much bigger value with 15,000uf x2. what are the pros and con regarding this amp design? and more listenable to sansui fanatics...thanks for any comments regarding my query..
I have both also and posted this exact same question a while back, got no response. Unfortunately I have still yet to perform the audition, but it will be done at some point. Keep us posted on what you find.
S.
Even though the 9500 is more "dual mono" the 8500 has more total rail capacitance. I would have to look at the schematics but I suspect the power amps are close to identical. Still it will be an interesting comparison.
S.
