thanks for athe help.
I decide to buy 9900 (because in here it is very hard to find 9500 999) and listen to it if i don't like the sound i will sell it and recap my 666.
I am shearhing for more power becouse i think it will give me more controlled bass.
But i will listen these amps side by side and make my decision.
BTW has anyone any knowledge how easy it is to convert 999 110v to 230v system
Very easy to convert a AU999 to 230V......
Which country are you based in?
If you like your AU666 you will definitely like the AU999, no question....
But I would plan on doing a full upgrade and the mods to the AU999, as it can be transformed into a legendary sounding unit with them....
I think in stock form they are OK, but more on the average side rather then the impressive side, but they are a wolf in sheep's clothing, mine sounds amazing.....
They need a mod done to the pre-amp so it can properly drive the poweramp section....
The Sub-sonic filter needs removing if it has one (later ones didn't have them).
Upgrade the main PSU ripple filters to 10,000µf.
Upgrade the bridge rectifier (the stock one is a bit on the weak side, and prone to failure)
Replace all of the "flying saucer" transistors, the driver board is full of them and on some of them so is the pre-amp.
I vastly improved the SNR of mine replacing ALL the transistors in the preamp...
They have this horrible protection device which needs removing, but just be aware if you do remove it, there will be no DC protection should something fail....
This is why a complete rebuild is the way to go......
Unfortunately I don't use my AU999 any more, I was thinking of selling it, but because it has been my development unit, I don't think i could bare to sell it.....
The good thing about all this, it that they are very easy to work on, modular and basic, just the way we like it....
Even a newbie with guidance can do all these mods and restoration work, the AU999 is one of the easiest amplifiers you could hope to work on....
