Assil
Member
Hi everyone,
I would to share with you my rather strange experience with a 1971 AU-999 recovered from scrap.
I renewed all transistors and Elec caps on all boards and some resistors. The PS reservoir Caps but I’ll replace them eventually. The Pots and switches were cleaned and as far as the F1159 boards are concerned, I replaced them with new spare boards.
I tested the preamp section successfully and the phono stage work perfectly. However I am facing the following issue with the power stage:
1. The amplifier sounds perfectly but I am unable to set the bias correctly due to the fact that whenever I put the speaker selector to OFF ( See Video) the series Safety bulb lights up. My understanding in such situation is that one of the channels of the amplifier is in saturation.
2. I checked the dc voltage of the main capacitors, and it drops from +\-41volts to around +/- 18 volts. I have checked the voltage across the resistors R854 and R856 on F1277 as well as resistors R853 and R855 on F1231. Following is my observation:
F1277-measurements
A- when speakers are connected (volume down to zero)
R854: 6.6 mV
R856: 0 mV
B- when speakers are disconnected (speaker selector switch to OFF)
R854: 281.9 mV
R856: 286.4 mV
F1231-measurements
R853: 1.2 mV
R855: 11.5 mV
R853: 0.4 mV
R855: 0.3 mV
3. While playing, in case I switch the balance check S17 down, the safety bulb will start flashing on and off as you can see in the video.
Please see the video link and photos attached. The video is on an iCloud link provided hereunder: https://share.icloud.com/photos/0F7MrrzujEK-rLVFAc8ynVGZA#Quatre_Bornes
In case you are unable to watch it let me know
Thanks for advising
Regards
Assil
F1277-measurements
R854: 6.6 mV
R856: 0 mV
R854: 281.9 mV
R856: 286.4 mV
F1231-measurements
R853: 1.2 mV
R855: 11.5 mV
R853: 0.4 mV
R855: 0.3 mV
Thanks for advising
Regards
Assil
