kevzep
Its all about the Music
Pre-amp and power-amp is separated POST the volume control.How would this work for volume control?
Not sure what you mean by that?It just doesn't allow signal processing?
Its simple, selecting speaker C is the same as pulling those jumpers out, whatever happens next depends on how you hook it up....
Oh I see what you mean, yes once the pre-amp and power-amp is separated, you will need to introduce an electronic crossover/processor to divide the full-range into discrete bands IE; Sub/Mid/High.....So the external crossover is needed for C outputs driving woofers as stated in the manual referenced above?
I can tell you 100% that speaker C separates the pre-amp from the power-amp, the pre-amp is full range.
ah very interesting!!
I was also wondering about some of this, as the manual also has a pair of full range speakers hooked up to C, in the diagram with the CD-4 etc
But the text explains what I ( sort of tried to figure out/quote ) above
The tone controls operate on all settings, each filter has its own bypass switch.Does this mean that tone controls will not engage when using the c speakers, but they will with a & b?
Yes you can do that, but remember as soon as you select A or B or A+B, the pre-amp is internally connected to the AU999 power-amp.So then I guess my question in regards to this is: Can I hook up one set of speakers (or a sub) to c, run y cables from the pre-outs to a separate power amp b-2102, and back in to the main ins on the au-999. Would this then allow me to run 2 sets of speakers off the c setting using the power amp and c plugs on the 999 (or a set of speakers and a sub) as well as use a and/or b for separate set/s of speakers?
No the speaker selector switch would operate as normal, but remember, on A,B A+B the pre-amp is internally connected to the AU999 power-amp.Or would the speakers connected to the power amp be active regardless of what setting the speaker selector is in?
The tone controls always work regardless of what speaker selection is engaged.In this scenario would volume and tone controls work for all speaker selections including controlling the power amp?
