Hi USA Soccer
There are a number of Sansui Amplifiers carrying the A (by which I think that you mean Alpha) 907 designation beginning with the Alpha 907 (190000Y(en),1986) and running through the 907 Alpha Limited (only 2000 units made, 410,000Y, 1994). The AU X1 was from 1979 and is listed at 210,000Y. There were also non-Alpha 907s including the D907 (1978,142000Y) which was the Japanese market version of the international AU 919. If I may generalize, the 907s were top of the line (TOTL) general production amplifiers made for the Japanese market (and so mostly 100V models that need a step down transformer for use in the US). Some had other model numbers if meant for the international market such as the AU 919. There were also special models along the way which carried the designation X, Extra, and Limited. The Alpha designation, I believe refers to the alpha-X balanced circuit which was introduced with the AU G99X/AU D907X in 1984 which characterized the newer Sansui amplifiers. The AU X1 predates the Alpha series. The 907 group is disparate in design characteristics, some use LAPT output transistors, the 907 Alpha Limited used MOS FETS. Few have compared the legendary Sansui models in one sitting. These would include the AU 111 (tube or valve amplifier as Hyperion might put it), the AU X1, the AU X1111 MOS Vintage, the AU 907 MR(X), the AU 907 NRA, and the AU 07 Anniversary.
To learn more, the two best resources of which I am aware are:
The Best of Sansui Website:
http://www.sansui.us/Issues_IntvsDomestic.htm . This lists domestic versus international models but the whole website is worth checking out including
http://www.sansui.us/issues_AU111vsAL907MR.htm .
and the Japanese Audio Heritage site
http://translate.google.com/translate?hl=en&sl=ja&u=http://audio-heritage.jp/&ei=t0TJSvXbFY3klAecqJySAw&sa=X&oi=translate&resnum=1&ct=result&prev=/search?q=audio-heritage.jp&hl=en&client=safari&rls=en .
You have to click on Sansui, then integrated, then click on your AU model of choice.
By the way, the AU 907 Alpha Limited at only 80 Watts rms into 8 Ohms makes the AU X1 at 160 Watts sound like a kids toy radio (I can't stop kidding, this is just meant as a little joke, no provocation to Daunia 70 or any one else intended). It is, I think very hard to compare TOTL vintage amplifiers (restored, non-restored?). My advice would be to take either if offered. The trouble is that with the AU X1 you are looking at a major overhaul that requires replacement of all black flag capacitors as well as other work, while the later Sansuis will work great for a few more years but the service manual are, for the most part, unobtainable. I suspect that the service manual for the Alpha 907 might be easier to come by that that for the Alpha 907 limited.
Regards
Marc
