Well, then I am right with not calming down about ~50+mV and wishing to get less! ))
In my opinion it was much easier to short the Power amps' (4266-67) inputs to ground and start the adjustment from the end (Power amp). Do you mean under "that provides a ground reference" that the input cable signal to Power amp has some offset even with no signal? - But specs of this signal is 0 +/-5mV then 0 is perfect. Or that the "ground" pin of the input signal connector is not wired with other ground on the board? But a thick ground wire is connected (shown red on the picture)
