JoseHH
Next I worked on the power amplifier stage. I started by unplugging one connector on each of the driver boards, and one from the main board. Several of the wires on the foil side of the main amplifier board (F4296) were not looking good. I removed all 4 wires that bring the rails to the board (blue-red and yellow-grey) and all other wires coming into the board form the foil side. Then I unsoldered black ground wires 40 and 43 from the driver boards. Then I removed 4 screws that hold the entire assembly from the bottom side of the sub-chassis. The whole assembly comes out. In this amplifier board F4293 is revision 3 which concerns mainly with the ground connections (more variants on this in this thread), and the values of the trimmers for the bias adjustment (330 Ohms from factory). I removed the two driver boards and the two protector boards leaving the F4296 as shown here:
Only 10 electrolytic capacitors, and 4 of them with glue. After removing the capacitors, and cleaning the glue, i removed all 4 trimmers, carefully measuring their set point resistance. In their place I installed Bourns 25 turn 500 Ohms trimpots. The originals measured from end to end were more than 400Ohms, probably due to oxide at the joints between the pins and the ends of the tracks. The wiper and one end are soldered together in the board so the 500 Ohm trimpots will work fine. I measured resistances from the remaining pin to the wiper pin and they were all in the 120 Ohms +/- 15 Ohms. I set each new trimpot to the corresponding value of the initial trimpots and installed them.
Then I replaced the capacitors. I used 4x Nichicon UKZ 470uF 50V, 2x Nichicon UKZ 100uF 50V, and 4x Nichicon UFG 10uF50V.
I did not change the 27V 1W zener (it is supposed to be RD27F). I set the main board it aside and worked on the protector boards (F4268 and F4269), only two 100uF 6.3V electrolytic capacitors in series per board (C7 and C8). I used one 47uF 25V and a jumper wire in the location of C7 and a wire jumper in the location of C8.
I am not sure if there is any other component to replace here.
