Sansui AU-X901 voltage problem.
All 4 trimmers set at 14mv across their respective resistor. Is this ok for further testing?….I hate to connect to normal power and then fry something… :oops:
Just turn the bias down until it is just noticeable on the meter say 2mV (remember to do all four!!) - then switch to full mains... and re-adjust.
Full power applied….same stuff….still blinking in protection. The main rails are +28.5vdc and -26.8vdc…seems low…..should be near 35vdc.
Nothing frying or burning…..I am stumped atm. All lights/selectors work as they should. I dunno’ what I am overlooking/missing…. :(
The ONLY tr that was blown was q6. Base voltages are not good….still to high q54/q55/etc. I have changed the 4 100ohm resistors each side. All others measure completely normal. Am I looking in the right place? On the E and B of the right channel main outputs, I have +/-11-14vdc. Could it be coming from the small protector boards?
Ok guys…with a probe at the kathode of d53, I adjusted vr2 from about -11vdc to -1.8vdc(as on scat)…and BAM…..relay clicked! No more blinking! I think the owner self-adjusted all the adjusters completely out of whack…..anyway, hopefully recovering now! Ok….we continue!
