daviddi922
Hi All,
I restored my all original Au717 last year following Leestereo's guide and parts list.
Before doing this, the channel would drop and would only come back on if I quickly turned the volume knob higher.
I thought cleaning all the switches and pots along with the rebuild would have fixed it.
Well, the last few months the channel will drop randomly. SO I removed the preamp-poweramp selector switch off the board, disassembled it competely, and reassembled it and it is now shiny and brand new looking.
I notice that right before the channel cuts out, it starts to get static and then will go in and out and then completely out. If I move the volume knob sometimes it will come back in.
Been trying to diagnose this this week so I took all the panels off the amp and had it playing trying to get the left channel to go out. Last night it finally did.
Things I noticed this time which was interesting: First time it went out, the protection relay kicked in and started flashing. After turning it off and back on. I was able to get the left channel to go out again, but this time I tapped on the speaker relay and it came back on while tapping and eventually stayed.
If I continued to tap on the relay, it would go out momentarily like the contacts were jumping.
So my question, could it be the relay thats bad even though I replaced it?
Should the contacts be that sensitive to the tapping that they lose contact?
Week voltage leading up to the relay?
I really just want to get this buttoned up and enjoying it. It was my dad's since he was in high school.
Thanks in advance!
Thanks in advance!
