Hello everyone.
After a lot of patience I was able to score an au777 with wood case. When it arrived I was surprised to see that no metal cover was under the woodcase...was the woodcase an option? No idea... inside was super dirty and a blown fuse. Checked the outputs... 1 of the d143 was blown and the 4000uf cap has been leaking.
After a complete recap and replacing the 2sd143 with d155 was able to set the current just fine. But I have no clue how to do the dc setting. I used to have an 777d which I set measuring dc across the
resistor of the outputs... worked fine but I never was confidently about that method...and it had a faulty volume pot as well, so I decided to sell it and look for another one until I was able to get this one.
About a year ago I was given a signal generator and an oscilloscope. So I thought I would be able to set the next 777 I get properly.
The service manual states to connect an oscillator at 1000hz my guess is that I needed to connect the signal generator at 1k in a sine wave signal but not sure about the frequency in hz...
I connected it to aux 2 as stated being careful with polarity...but i don’t get a sine wave signal at the oscilloscope....
while increasing the volume a puff of smoke came out and thought I have blown the outputs... but it was the 10ohm 1/2w dummy I put at the speaker terminals.... so it was fine.... phew....
any ideas of what can be wrong? Pretty sure a lot, but any ideas would be really appreciated.
Thank you
Thank you
