yadvinders
I have the circuit diagram, didn't find the service manual can some one facilitates me with this content, your kind help is much appreciated.It's in the Service Manual, page 14.
Thanks in advance
First please download a copy of the Service Manual, you will need it. It also contains the DC and bias setting guides even though it might not be 100% clear how to do it.
In it you will find the following values for variable resistors:
Sansui B-2301 Stereo Power Amplifier Manual | HiFi Engine
www.hifiengine.com
Yes.Can we use the 2k Ohm & 500 Ohm as direct replacement
Don't want to sound critical, but did you even bother to check the link on HiFi Engine that Magnus Back provided ?didn't find the service manual can some one facilitates me with this content
After all these questions I've been on the edge of making a post like that.The B-2301 is not something a novice should be messing with. Even the most experienced Techs find these amps complicated.
It will make an excellent doorstop if your not careful
Yes bias does affect the sound of the amp.Hi
I have service manual of the Sansui 2301 amplifier, tried to adjust the DC offset, because its out of specs, which is already set in permissible limits, now come to Bias adjustment, just measure the Bias on either end of main driver board, it’s in the range of 0.7 to 0.8 m volts, which need too set to be around 20 mv at all test points as per service manual, But amplifier running good, but as I feel low end response seems to be missing, does bias really impact the sound of amplifier
2nd in the service manual say 90 map at R71 & R74 of driver board, I think these are accessible from bottom by opening small plates.
Have complete Japanese manual with me, its scanned copy not able to translate, can someone translate the page no 14 only or assist me to adjust the bias adjustment.
What is the role of 2 variables on board no 3768 mounted on the back of amplifier, where to measure the dc voltage for the adjustment?
Thanks in advance
Thanks a lot, now technician will understand this & fix the issue with help of manual.
Set the bias to the Service Manual figure of 20mV after 30 minutes warm up - as per the chart posted in post #28.Any recommendation on it
