Sansui BA-3000
møs1
Out of range
HI
In my BA-3000 there is different types of
2SB600/2SD555 transistors, it is possible for me to
buy some original Motorola MJ15025/Mj15024 from same serie.
Is there somebody out there who have some expierence in
use those transistors in a BA-3000, and will you rekommend
me to use them in the amp?
Thanks
Hi Møs1
Original transistors should be Sanken.
I have sent you a PM with a possible source on ebay, where I got original Sanken TO-3 house spares for my AU-20000.
BRgds Klaus
Semiconductor supplier
I just ordered some original Sanken and Toshiba semi's from Consolidated. He had everything I needed and Ok prices. You can find him in the supplier sticky under CEITRON.
Do not use the ON/Motorola devices. They have considerably narrower bandwidths than the 2SD555 and 2SB600. By subbing the MJ15024/25, you run the risk of converting your BA-3000 into a giant oscillator.
By the way, the BA-3000 is a lovely machine! We have one in for service right now.
Fred
Hi
Thanks for your advices, i`ll follow them and
use Sanken instead of Motorola:thmbsp:
