Sansui CD Player & Remote's
Which Sansui device was the one which had it (RS-1890) regulary sold with? (The CD-a607?)
I have the CD-a607 brochure but the picture is too small too see the model number on the remote. I would guess the RS-1890 is intended for the 1999 CD-a607 and the 1994 RS-1590 for the CD-a907XR (those dates may not be exact but should be close). Based on numeric sequenced to chronologic. Just a guess!
new stuff found:
RS-900R: RG900
RS-1080: also for RZ-7000
RS-1260: AU-V7000
RS-1290: RZ-9500AV
RS-1380: AU-V7500
RS-1540: AV-9000DSP
RS-1550: AV-8800DSP
RS-1560: RZ-8100AV / RZ-7900AV
RS-1680: A-a9
RS-1890: CD-a607
RS-H11: MS-6901 compact system
RS-S126B: RZ-5110AV
RS-7T: System 77 (B-77/C-77/T-77)
unknown: RS-F14
Compiled full list:
RS-100: Remote controlled Receiver RS-100 for volume control
RS-900R: RG900
RS-1000: b-3000/c-1000/t-1000/d-3000wr/p-2000
RS-1010: cd x701 / cd-a907
RS-1020: cd x501i, x701i
RS-1030: cd x301(i)
RS-1040: da-alpha 607i
RS-1070: rz-3000 / rz-3500
RS-1080: rz-5000 / rz-5500AV / rz-7000
RS-1090: cd x510m / cd-m12
RS-1110: cd x711
RS-1130: au-x911dg
RS-1150: cd x211, x311
RS-1160: au-x611av
RS-1210: cd x111, cd 2700
RS-1220: rz-1000
RS-1260: au-v7000
RS-1290: rz-9500av
RS-1350: cd 3100m, cd 570m
RS-1360: cd-a717dr
RS-1370: cr-280
RS-1380: au-v7500
RS-1390: cd x317
RS-1420: cd x217
RS-1460: cd x117
RS-1470: cd x317
RS-1510: cd 390m
RS-1540: av-9000dsp
RS-1550: av-8800dsp
RS-1560: rz-8100av / rz-7900av
RS-1580: cd x319
RS-1590: cd-a917xr
RS-1680: A-a9
RS-1690: cd-α7 / cd-α9
RS-1890: cd-a607
RS-2000: b1000/v1000
RC-2900: RZ-2900
RS-E770: A-E770/CD-E770/D-E770/T-E770L
RS-F22: MC-X5 compact system
RS-S103: CD-190
RS-S104: MS-3955 compact stereo
RS-S116: RZ-6100AV
RS-S126B: RZ-5110AV
RS-S138: CD-210
RS-V550R: CD-V550R
RS-V1000: PC-V1000
unknown yet:
RS-F14
RS-F18
RS-F26
few new findings over time:
RS-1410: rz-2500 (rz-3500 too???)
RS-1490: AU-X417R
RS-880: SE-88
RS-1710: MD-α7, MD-α9
RS-1490: AU-X517R
RS-J1: A-H7, T-H7, D-H7, CD-H7 compact system
RS-G6: MC-X950 compact system (A-X950/CD-X950/D-X950/T-X950L/S-X950)
new unknowns found: RS-1520 / RS-1570 / RS-1500 / RS-G1 / RS-G2 / RS-F5 / RS-H9 / RS-1800
Compiled full list:
RC-2900: rz-2900
RS-880: se-88
RS-900R: rg900
RS-1030: cd x301(i)
RS-1110: cd x711
RS-1130: au-x911dg
RS-1160: au-x611av
RS-1220: rz-1000
RS-1260: au-v7000
RS-1290: rz-9500av
RS-1360: cd-a717dr
RS-1370: cr-280
RS-1380: au-v7500
RS-1390: cd x317
RS-1420: cd x217
RS-1460: cd x117
RS-1470: cd x317
RS-1490: au-x517r
RS-1510: cd 390m
RS-1540: av-9000dsp
RS-1550: av-8800dsp
RS-1580: cd x319
RS-1590: cd-a917xr
RS-1680: A-a9
RS-1710: md-α7, md-α9
RS-1890: cd-a607
RS-S103: CD-190
RS-S116: RZ-6100AV
RS-S126B: RZ-5110AV
RS-S138: CD-210
RS-V550R: CD-V550R
RS-V1000: PC-V1000
unknown yet:
RS-1500
RS-1520
RS-1570
RS-1800
RS-F5
RS-F14
RS-F18
RS-F26
RS-G1
RS-G2
RS-H9
Thank you for posting this. Are there any recommendations for a Sansui CD-changer?
Are there any that were well-made and worth considering today, or any to avoid specifically? I have a completely great Yamaha, but my OCD to be fully Sansui...well, it's overwhelming.
Thank you, fellow Sansui enthusiasts!
I guess you should start your own topic in the Sansui subforum, where you get more detailed response, as this is the Sansui's remote control thread. Except for the CR-280 I don't know about further of these Sansui CD-chargers (and I know it because I found the info for a remote for it), but I can be wrong of course.
My apologies - I appreciate the comment, I misread and do not mean to derail this conversation.
Peter can you add the CD-a717D LTD to your list? It looks from the comments that 1590, 1390 and 1360 all apparently work with it. I have a CD-a717D LTD on the way so I can confirm once it's here and dig out my Sansui CD remote collection. BTW I have some spare remotes if anyone is looking for one, PM me.
Oh that I have no idea. I thought your list was a compatibilty list. From the comments in the thread it looks like three will work with the CD-717D LTD. It did come with remote from the factory but I am not sure which. I haven't found a manual yet and can't make out the number in the picture. Do you know which was shipped with it?
Not one of the four I already own - RS-1680, RS-1690, RS-1890
Oh well compatibility... the RS-1460 from the CD-X117 works for most functions of the CD-717DR but nothing works for the CD-X701i. Different standards and lambda maybe. My list compiles the remotes that were originally sold with the Player :)
Two more confirmed for compatibility -
CD-a717D LTD works with the RS-1890 and mostly with the RS-1690. Pause from the RS-1690 does not work, bizarrely. And the CD-a717D LTD does NOT work at all with the RS-1680.
@JimEGR,
Sansui was all over the place with remotes in that era. I wish I knew why the compatibility of remotes was so fragmented, most of these players were in house developments, with some technical contributions from Technics (MASH) and a couple of models that use high spec JVC optical blocks. Given the support logic was done by Sansui (or to their specs, in any case) it makes little sense that there are so many incompatibilities, especially across fairly closely related models.
Part of the reason for the pause issue is that the remote pictured on the left has a unified play/pause button. The remote on the right has separate buttons for each function. I've run into this with some early Technics players as well. Some had play and pause as separate controls, others had a single button as an alternating state dependent control.
Might be worth noting too that most of Sansui's earlier CD players were just rebadged Toshiba players, and at least one was a rebadged Yamaha. Toshiba was a prolific OEM of CD players to several others companies, including Sansui, Kenwood, and Luxman in the 1984-88 timeframe. Thus, many such models can use remotes branded for any of those interchangeably. There is no such clarity for the 90's era players, unfortunately. I have a large master code listing for UEI universal remotes, that might bear out what other brands might be code compatible, and gain us some insight into possible OEM suppliers who.had a hand in these later players.
@JimEGR,
Specifically which early Sansui CD players were rebadged Toshiba's? Just the entry level stuff? The CD-a907's must have been all Sansui - they are so unique and so overbuilt with all of that copper and Sansui transformers.
The remote control compatibility is pretty frustrating considering how so many crossover. I think I have been through a dozen or more Sansui CD players and most of my remotes crossover between models.
I would still like to know which came factory with the CD-a717D Limited.
Mostly the PC-V series models. The PC-V750 was an Toshiba XR-Z40 rebadged. The PC-V100 was a Yamaha CD-X1 rebadge, the PC-V300 was a CD-X2 rebadge. The origins of the PC-V1000 and 500 remain more mysterious, as they are both ultra rare. These appear to me to still be heavily reworked versions of other players, but it's unclear where they got their start. I'd have to see the guts to make that call.
I suspect the 500 started life as Yamaha hardware to some extent, as it is a arrower "midi" sized component. The 1000 may well be partially of Toshiba origin, but more heavily customized to reflect a top of the line offering. Luxman had a couple that were Toshiba sourced, but were more difficult to ascertain that from their significantly changed outward appearance, and heavily customized electronics. These were the first generation models, 1983-85 or so.
One notable commonality among virtually all early Toshiba players was a combined pause/stop button. I believe they were the only OE to adopt that user interface peculiarity, and it was also found in all models built around Toshiba designs, as it was a fundamental feature of the control panel logic used.
For the second generation (CD-Xn01 and CD-an07, plus the slightly later variants with the "i" suffix) these appear to have been fully in house designs by Sansui. I own a 501i, 701 and 701i, and have noted nothing of the internal electronics that appear to be appropriated from another player sourced from a different manufacturer. Same goes for the subsequent generations into the 90's. Then when we get to the CD-a7 and CD-a9, there is a line of midi sized players by Denon from around the same time frame that is suspiciously similar, but I've not managed to snag one of the Denon models in question to make a comparison, so that may just be coincidence.
Few updates.
RS-1460 is for CD-117, not CD-X117
RS-1470: for CD-X617 too
RS-1080: for rz-5500AVII too
RS-1480: AU-α507R
RS-1770: MH9 system
RS-1820: MD-10MH compact Hifi
RS-V550R: CD-V550R
RS-A2: unknown
RS-1700: unknown
RS-1830:: unknown
RS-E1: unknown
RS-F2: unknown ("digital-e-compo system remote controller")
RS-F3: unknown
RS-F11: unknown
RS-G4: unknown
RS-H2: unknown
RS-H14: unknown ("Mini Component System Club Sansui")
RS-J2: unknown
RS-S101: unknown (seller said "CD 117 MK 2" but I haven't found a proof for this)
RA-1100: unknown
Compiled full list - 2026/02/17:
RC-2900: rz-2900
RS-880: se-88
RS-900R: rg900
RS-1030: cd x301(i)
RS-1080: rz-5000 / rz-5500av / rz-5500avii / rz-7000
RS-1110: cd x711
RS-1130: au-x911dg
RS-1160: au-x611av
RS-1220: rz-1000
RS-1260: au-v7000
RS-1290: rz-9500av
RS-1360: cd-a717dr
RS-1370: cr-280
RS-1380: au-v7500
RS-1390: cd x317
RS-1420: cd x217
RS-1460: cd 117
RS-1470: cd x317, cd x617
RS-1480: au-α507r
RS-1490: au-x517r
RS-1510: cd 390m
RS-1540: av-9000dsp
RS-1550: av-8800dsp
RS-1580: cd x319
RS-1590: cd-a917xr
RS-1680: A-a9
RS-1770: MH9 system
RS-1890: cd-a607
RS-S103: CD-190
RS-S116: RZ-6100AV
RS-S126B: RZ-5110AV
RS-S138: CD-210
RS-V550R: CD-V550R
RS-V1000: PC-V1000
unknown yet:
RS-1500
RS-1520
RS-1570
RS-1700
RS-1800
RS-1830
RS-A2
RS-E1
RS-F2 ("digital-e-compo system remote controller")
RS-F3
RS-F5
RS-F11
RS-F14
RS-F18
RS-F26
RS-G1
RS-G2
RS-G4
RS-H2
RS-H9
RS-H14 ("Mini Component System Club Sansui")
RS-J2
RS-S101 (seller said "CD 117 MK 2" but I haven't found a proof for this)
RA-1100
