Hello all, I'm a long time lurker turned new member. I recently purchased a Sansui G-5500. The seller said it worked when he shipped it. It was packed very well with plenty of padding, bubble wrap, packing peanuts, double boxed, etc. and it didn't look like it had been dropped (but who really knows). It took me nearly 30 minutes to unbox it. Anyway, I plugged it in and pushed the power button and nothing happened. I've replaced the fusses and still not luck. I've tried wiggling power switch/wires to see if there is a short or something came loose but nothing happens. I'm hoping some of you might have suggestions on what I can try. I've carefully cleaned the circuit boards with air while I've had it apart. Minus a pencil wedged inside (not sure what for), everything looks nice and tidy including solder joints, there isn't any evidence of burnt parts on the circuit boards or anything like that. Is there some points I could test with a multi-meter? Anyway, let me know what you think and thank you for the help! I can provide pictures if you need a closer look.
