OleJeepGuy
After much searching and reading, I didn’t find the answer to my question. So here we go.
I recently brought home a Sansui G8700db. I just finished rebuilding the audio section. But before I plug in the rebuilt F3074 driver amp boards, I wanted to check all the units power supply outputs.
With both F3074s & the Output Power transistors removed from the unit, I connected power cord thru my DBT. I pressed the units power button and here is what happened:
DBT light ramps bright but within a couple seconds, dims to very dim. This is normal behavior.
I noticed the Soft start protection relay (RL601 on F-3072 Protection board) did NOT set. But after a few seconds, RL602, the speaker protector, clicked set and the front panel Protection LED went from flashing green to solid green.
So with the AC power relay not setting, I noticed 2 things:
The input voltage drops from 119vac to around 90vac.
I then measured the Transformer output.
The power transistor collector voltage s/b +/-75vdc, but tops out at +/-55vdc. So, Input ACV drops about 26% (T701 input) and the DCV output drops a similar 26% (T701 output thru rectifier).
All during this time unit is running with no smoke, no smells, and no heat anywhere I can feel.
I’m thinking all of this AC anomaly is due to Power protect relay NOT setting.
And now for my question:
F3072 IC1 (HA-12002) houses the power protect logic.
What power parameters will prevent IC1 from setting RL601?
Does anyone have any tips on how to troubleshoot this logic?
Thanks in advance.
Thanks in advance.
