stereo_dog
Well-Known Member
I have a Sansui G-9000 that I've been having some phono issues with. The unit has been humming along without an issue for several months, now. Last week I decided to connect a turntable to it for the fist time in several years. Connected a TT, played several albums, no issues. The next day, fired up the system, low output on the left channel while playing an album. Checked all other inputs (aux. which is a CD player, tuner and tape) no issues, robust output from both channels. So I unhooked the current TT, replaced it with another known working unit, same issue, low output on the left channel.
I them took a break to do some family stuff, and came back a couple of hours later. Fired up the TT, no issues, good sound out of both channels. Switched TT out, same result. Spent the rest of the afternoon spinning vinyl, maybe 4 hours worth, never another problem with the left output.
Fired up the system again, last night, problem is back, same issue, low output from the left channel, again, only in phono. Tried both phono inputs, same result. Tried second TT, same result. The only difference, last night I accidentally touched the ground wire at the receiver, and the left channel got slightly louder.... not sure what that means.
Any suggestions as to where to start looking for the issue?
Thanks.
Edit. Forgot to mention, playing with the switches has no effect on the left channel output, except when switching from stereo to mono. When in stereo, low output, mono normal output both channels.
Thanks.
