2nd owner, had it for the last 20 years; previous owner also nursed it (friend's dad, so I've known this unit my whole life. In fact this unit knows probably more about me than myself)
Over the last 3 years it
- started to go on Protector while using
- then simply wouldn't come off Protector when trying to launch
I realised that one of my F2806 boards wouldn't "keep" its DC bias value setting, it would greatly swing.
But I did the unthinkable ... I misaligned the left side board by one pin when inserting it back in ... and magic smoke came up from the left F2806.
Instead of debugging, I grabbed two fresh F2806 bare boards designed by Hipocrates, I believe sold by EastPoint (I can't thank the universe enough for their existence) and soldered on.
The boards seem ok; I swapped each of them with the previously known good F2806 board (the one I didn't fry) and I swapped their positions in the unit - exact same results each time; so I conclude tha tmy boards are at least at par with the original one.
The problem right now:
It will go off Protector but ONLY when plugged in through a dim bulb.
It will go off Protector ONLY if I crank the right side DC Bias upwards of 50mV (I Swapped the boards from left to right, and it behaves the same - meaning the F2806 board is probably not at play, but rather the right side power supply ?)
No matter what I try (and I don't usually try much, or for extended periods for fear of breaking stuff) WITHOUT the Dim Bulb - no values of DC Bias on either side will make the Protector disappear. (I didn't try extreme values, but 16mV or 30, or 80mV... on either side or both at the same time... nothing happens.)
I also "feel" like the LEDs are much less powerful than they used to (with or without Dim bulb) -- I know its subjective but if my memory serves me right, the LEDs used to be me retina scorching powerful.
I haven't gone through the motions of re-capping any of it;
When plugged in with Dim Bulb and protector off - it plays wonderfully, both through the Pre-amp or direct to the power amp. But I don't play it for extended periods of time since I assume its not operating within specs.
My question is... what would be your next troubleshooting steps ? I don't feel like swapping caps for sake of it, but I'll gladly do so for the bad ones. My issue is I don't have a tester that can test in situ, so that means desoldering them or 'observing' for obvious leaks and stuff.
I'll take a look at F2808 and 2807 tonight, but I don't feel courageous enough to attack 2809 just yet (unless instructed otherwise here)
Thanks in advance
Thanks in advance
