I am trying to find a service manual for a Sansui G-9000DB, I I can find is a G-9000. Not 9000DB. Trying to find pot to adjust to bring the tuning meter in the vertical center. It is 3/4 to the left. The signal is good. Thinking it might bring it into stereo since the LED lamp it does light. up. Checked the LED and it is good, Perhaps the FM IC but what is the HA#? Anyone know?
DB non DB, same tuner board.
The difference is a separate Dolby FM de-emphasis board which will have no influence on the issue you're having.
To properly adjust the meter position you will need to perform a proper alignment and so along the way be able verify the tuner is operating correctly. One thing can easily affect another in the world of tuners.
RF, IF, Discriminator, MPX adjustments and so forth.
There can be several reasons why the meter is not centred. It could be an incorrectly adjusted discriminator, and if it is, you do not want to be just correcting the meter without knowing why it's like that. You may have more than one issue.
You will need a RF signal gen, distortion analyser, MPX generator, scope and a whole load of RF experience.
The issue will be easy for a RF tech to solve, but if you dont have this, I wouldn't mess with it. Get it to a tech.
The G9000/9000DB tuner is an excellent performing tuner and most worthy of a proper alignment to ensure optimum performance.
