If anyone has any ideas, or has dealt with a similar issue on a G-9000/G-901, I would really appreciate any additional troubleshooting suggestions that might help me narrow down the cause of this transformer buzzing.
Issue:
The unit powers up normally, comes out of protection, and plays music. However, the power transformer produces a noticeable mechanical buzzing sound. There is no hum or buzzing through the speakers.
Here are the troubleshooting steps I have taken so far:
If anyone has seen this before or has suggestions for additional measurements or isolation tests that would help determine whether this is excessive current draw versus a defective transformer, I would appreciate the help.
Thank you,
MecII
Issue:
- With all secondary feeds to the F-2807 and F-2808 boards disconnected from the transformer, the transformer is completely quiet — no buzzing at all.
Transformer secondary - voltages measured with secondary leads disconnected.
- Secondary voltages feeding F-2807:
- 52V winding reads 54.37V
- 52V winding reads 54.33V
- 32V winding reads 33.18V
- 32V winding reads 33.29V
- 50V winding reads 52.54V
- 50V winding reads 52.55V
- Secondary voltages feeding F-2808:
- 50V winding reads 52.45V
- 7.5V winding reads 7.48V
- Reconnected the secondary feeds to F-2808 only (50V and 7.5V), while leaving all feeds to F-2807 disconnected.
- Result: Very slight transformer buzz.
- Reconnected all secondary feeds to F-2807 as well.
- Result: Transformer buzz becomes loud.
- Disconnected the 52V and 32V feeds to F-2807, leaving only the 50V feeds connected. All feeds to F-2808 remained connected.
- Result: Very slight buzzing, but nowhere near as loud as with the 52V and 32V windings connected.
- Reconnected the 52V feeds to F-2807 while leaving the 32V feeds disconnected. All feeds to F-2808 remained connected.
- Result: Transformer buzz is at its loudest. Seems to be tied to the 52V.
- Reconnected all secondary feeds to both F-2807 and F-2808. I then disconnected the brown and blue output wires from F-2807, which supply the approximately +/-72V rails to pins 6 and 7 of F-2809.
- Result: The loud transformer buzzing stops.
- From there, I tried disconnecting the various connectors/cards downstream of F-2809 that I could safely eliminate from the circuit.
- So far, nothing I disconnected downstream eliminated the loud buzzing when the +/-72V supply from F-2807 was connected.
- Something downstream is drawing excessive current and placing an abnormal load on the transformer, causing it to mechanically buzz.
- The transformer itself has developed a mechanical/internal problem and becomes noisy once it is placed under normal load.
Thank you,
MecII
