angelaudio
I got this big beast today in non-working condition. Upon powerup the protect light starts blinking and stays that way. So I opened it up and there was no apparent issues up top under the cover, the underside though was a different story. Upon removing the bottom cover I immediately spotted an issue: some burnt components on the F-3073 board
A Quick Look at the schematic revealed that these burnt components are resistors. I can’t tell if they are all burnt or if it was just one that blew and burnt the other two. According to the schematic these three resistors are R01, R03, and R15 from bottom to top.
What could have caused these resistors to blow? And secondly how can I safely remove the board for maintenance? I removed the 4 screws at each corner but there seems to be another board attached to the opposite side of F-3073 and I cannot remove it.
In addition to the issue on this board I did notice a resistor replaced at F-3072 which may be helping in identifying what failures could have previously occurred. The big gold resistor at the bottom right of the board is the one I’m referring to:
