Sansui Lateral and anti-skate weights & dimensions
Hi, after trawling though numerous posts its seems to be a common and very seldom answered question for the weight & dimensions of both the lateral and anti-skate weights of various sansui turntables. I own 3 tables (SR-212,SR-313 & SR-525) and i only have the anti-skate weight for the SR-212. After doing much searching i've found the weight of both weights for the SR-525 and the dimensions of the lateral weight from threads on this forum which i'll try and link. I was thinking it would good if anyone who has weights on their turntable (what ever model it is) and the facility to measure or/and weigh them, if you could post them here and maybe start a sticky to help anyone in the future it would be much appreciated.
Im really needing the SR-313 weights and dimensions if anyone has them? The SR-717 also seems to be a common one asked if anybody has them?
I've got a couple of lathes so im going to be manufacturing the weights which im missing. i'll post some pics of them finished and if anyone is needing ones as im sure i could fabricate some more up.
SR-212 anti-skate
Weight = 1.6 grams
Diameter = 6.73mm
Length = 7.72mm
Thread Length = 74mm
SR-525 anti-skate
Weight = 2.43 grams
Diameter = Unknown
Length= Unknown
Thread Length = Unknown
Post Link -
SR-525 Lateral
Total weight = 14 grams
Rod (fixed into weight) Diameter = 1.95mm
Rod Length (From Bend) = approx 38-40mm
Weight Dimensions = 10.7mm Diameter x 17.3mm Long
Post link - http://audiokarma.org/forums/index.php?threads/sansui-lateral-weight.530672/#post-6923241
SR-212 anti-skate
Weight = 1.6 grams
Diameter = 6.73mm
Length = 7.72mm
SR-525 anti-skate
Weight = 2.43 grams
Diameter = Unknown
Length= Unknown
Post Link -
SR-525 Lateral
