Just realized I've lost sound on the rear right channel of my QR-4500. This occurs when playing the unit set to "normal" 4 channel mode. When I rotate the sound (1/4 or 1/2 turn) the rear right comes in, but the lost channel follows the selection. So for example, 1/4 turn left brings sound to the RR channel, but now right front channel has no sound. Also, if I select "front + rear" or rear only, I get sound on the RR channel.
Moved front/rear and rear left/right balance controls to isolate the RR channel. When I turn the volume way up, thiere is faint sound on the channel. Also, slight scratchiness from the volume pot is at normal volumes on the channel.
Opened the unit up and since the driver board appears completely symmetrical, I flipped it around in the connector. This would flip which channel is going through which side of the board. However, the problem did not move with the flip, the RR channel still had no sound. So, I don't believe the problem is on the driver board. Also checked the fuses for both rear channels and those are good. Used Deoxit and Fader Lube on volume pot and all balance sliders to clear up scratchiness and get rid of any possible dead spots.
Problem is the same no matter if source is 4 channel AUX or synthesized quad from tuner.
Not really sure where to look next. Any ideas??
