jeeem
I'm bouncing back and forth between two recent acquisitions that need just a little work. Both are Sansuis, a QRX 7001 and a 551 -- and both were recommended to me by the trusted posters at AudioKarma, so I can't wait to get them up and running.
But first... I'm having trouble figuring out how to change the burned out bulbs in the 7001 because I can't find a way to access the front panel lamp fixture. I couldn't find a way to take the faceplate off of this model, and the service manual isn't clear about how that is accomplished. And it's such a tight squeeze that I haven't been able to lift the plastic fixture out. It takes 6-8 volt fuse lamps to light the radio dial -- the little incandescent bulbs you see hanging out here are just for the various functions.
Do I have to dismantle the whole unit in order to accomplish what I thought would be a fairly quick-and-easy task? Here are the innards at this moment:
BTW, it shows them in the "exploded view" in the service manual..
