Hi Everyone,
New member and new owner of a vintage one owner QRX-7500A. Just replaced all the fuse lights with LED's and fixed a few cold solder joints and fuse issues. Everything is working great including all inputs, knobs, and strong FM.
The only thing not working is AM. It has the original ferrite antenna, and I tried a loop and several other antennas attached to the AM slot. I'm only able to occasionally bring in 1 or 2 AM stations. I'm not sure where to start to troubleshoot this and achieve a stronger signal and pull in more stations. I've done quite a bit of solid state repair but never worked on a vintage stereo. This thing sounds absolutely amazing and I probably won't use the AM radio that much, but I want everything 100% when I put it back in that beautiful wood enclosure.
Any help would be greatly appreciated.
Thanks!
Thanks!
