xoaphexox
Supernatural Anesthetist
Tonight I finished restoring my 3rd Sansui QRX-777, the Euro version of the QRX-7001.
Usually as I move through I pitch the old parts in the trash and keep moving. I read an old exchange on AK between QuadBob and Echowars and it made me think this time I decided I was going to keep the parts I swapped out to get an idea of how much work and replacement parts was actually involved.
There were a total of 209 electrolytic capacitors to replace!
The amp was pretty straightforward because it was working before I decided to restore it.
I replaced the relay, ripple filter caps, fuses, tantalum caps, electrolytic caps, lights, fusing resistors, thermal paste, and mica insulators.
I added vishay roedersteins across the ripple filter caps (trick I learned from Dr*Audio).
Then I gave it a thorough cleaning, adjusted bias, offset, and preamp supply voltage to spec.
Then I used the information contained on this site http://hometown.aol.com/matrixquad/sansui.htm to dial in the QS synthesizer boards to spec.
If only I had the proper equipment I could align the FM as well, but this unit was pulling in stereo FM stations from my basement where I can barely get cell phone reception, let alone FM, so I think the tuner is good to go!
Here is a pic of the parts replaced:
Listening to a Warren Zevon album (Excitable Boy) and it sounds fabulous!
