I need help with my SC 3330 cassette deck which has an issue with the tension arm assembly. In play back mode the tape take up tension is to loose and disengages during playback causing it to stop playing (like end of tape). When I remove tape there is about an inch of tape that has not been wound up. Does anyone know how to remedy this, I am not sure if the felt pad or spring tension on the tension arm assembly (part # 111) is the problem. I have had a new belt kit installed and all other functions work as expected. I have posted here on the Sansui forum and not had any reply's so I am hoping for help here. Any help would be much appreciated.
Thank you
Doug
Thank you
Doug
