Enrique Vega
Hello guys
I'm new to this forum, I have a Sansui SE-88 that has a dimmed display and I want to try to fix it before sending it to service. I have fixed some amps and other EQs my self but I do not do this for living and I might not have all the knowledge to troubleshoot this right away.
Here is what I have done:
First I got the service manual and checked the power supply voltages, since it's hard to measure with the EQ assembled I carefully took it apart and got the power supply unit alone.
I was expecting to see some lower voltages but surprisingly is not the case voltages are mostly right matching the service manual.
But this was measured disconnected the rest of the components only the power supply board that includes from the transformer up to the final DC supply pins.
So now I guess the problem is in the same board that is attached to the displays and is a little too delicate to mess and play with it without having a real idea how to find the reason why the display is dimmed.
Any suggestions would be really appreciated, I really want to get it back to the normal display.
I'd like to hear from other members in this case normally what I would do is try to visually check for bad caps or resistors but I was not able to see any potential issue, I want to avoid desoldering one by one caps or res to check which one is bad.
Can someone if possible suggest me a way to find the issue without desoldering or risking the display?
The service manual file is too large to be attached here is the link
https://www.manualslib.com/products/Sansui-Se-88-5886472.html
I also attached a picture comparing to a Kenwood GE-920 to show how dimmed it looks.
Thanks !!!
Thanks !!!
