Does anyone know how to determine the (exact) age of the unit? There are numbers located on the inside of the wood cabinet and the faceplate but I have no idea if they correspond to anything.
I can also provide an image of the said sticker, maybe someone can get some information out of it by adjusting contrast, brightness etc
There may be a way to date it by the faceplate. Is there a paper label on the back of the faceplate? If so, please post a picture. Also, in the future please use this format:Sansui Six: 824020380
Sansui Seven: 813010554
I also own a Sansui Eight, but unfortunately someone partially scraped off the serial number sticker. Does anyone know how to determine the (exact) age of the unit? There are numbers located on the inside of the wood cabinet and the faceplate but I have no idea if they correspond to anything.
It also seems to be an early unit as it has the original crowbar protection instead of the relays and FM range only up to 104 MHz (as far as I know later European versions had the range up to 108 MHz)
What purpose would be served by including units without serial numbers?
- Pete
Okay, will do that next time.There may be a way to date it by the faceplate. Is there a paper label on the back of the faceplate? If so, please post a picture. Also, in the future please use this format:
Six,82402038,DoenerBoy123
Thanks,
- Pete
If it has a date code on the faceplate, it would be in a paper label on the back of the faceplate. If I'm remembing correctly, these labels use some sort of Japanese calendar to display the date. I don't know how to read it. They were discussed in the early days of the forum.Okay, will do that next time.
I attached pictures with the numbers of the faceplate, the woodcase and the partially removed serial number sticker.
View attachment 2943350View attachment 2943365View attachment 2943369
