Hi all - I gearing up to restring a Sansui Seven. I have the SM - and it seems straightforward enough. But what is existing (original?) doesn’t match the manual. Instead of each string being essentially tied on either end of a spring- one end on the spring, the other on the screw post. The existing uses the spring in tension but in a different way. The string runs through the end and is also tied at the screw.
Anyone else see it done this way?
Any reason not to do it via the SM?
Thanks!
