Hi all, this is my first post on the forum. I have a pristine (externally) pair of Sansui SP-2000's that I got as a gift from someone. I've had them for about a year, but I just now decided to take off the front grilles and take a look inside. It seems to me that the 5" and 6.5" are both not working. I've decided to recap the crossovers and see if that'll fix it before I purchase any new drivers. My questions are as follows:
1. In adding the 0.01μF foil bypass caps (as per archibael's instruction), will it be a big detriment if I skimp on the AudioCap brand and go with Dayton, what every other cap is? Its a savings of almost $20 per speaker, going with AudioCap would nearly double the cost of the project.
2. If I do end up replacing the two midrange speakers, will the crossover's effect be drastically changed, or will the speaker have any issues if I go with a different impedance rated speaker? OakTreeVintage.com rates those speakers as being 16Ohms, but nearly all speakers on parts-express are 4 or 8 ohms, as I thought nearly every speaker was.
Side note, the speakers are currently running on a sad little Teac AG-V1200 receiver. I am hoping to get my hands on the original Sansui amplifier that was paired with the speakers, but if not, I will most likely hook it up to my Yamaha RX-V477 via the little bear tube amp that's currently en route to my house. The only thing connected to them is a Pro-Ject Debut Carbon DC turntable.
The RX-V477 has a set of Fluance-AVHTB speakers + a 10" Polk Audio powered subwoofer connected. If the wise elders of this forum recommend going with the $250 Fluance set over the Sansuis, I can try that too.
