Sansui SR-2050C Inside Force Canceler Weight
patleaver
My Sansui SR-2050C is missing the Inside Force Canceler Weight (weight that hangs from a line). If I wanted to rig one up, how many grams should the weight be? I was also thinking of using monofilament line, how long should it be?
Here's some more data on 2050C, as I just got done setting one up again.
Overhang/Alignment: 19/32" or 15mm, measured by swinging arm directly over spindle, and measuring from center of spindle out to the stylus.
Antiskate: The notches correspond with 1/2 gram increments, from inside to outside of the notched arm.
Arm Counterweight: Jack the rear of the turntable up 4 inches. Adjust the counterweight so that the arm neither swings in or out in this position.
Arm length: 220mm
