BilboBaggins
Addicted Member
Awesome! Way to go @Madeline12!
You are one hundred percent correct. I’ve decided to return to this turntable again, hoping to make some progress. The grommet spacer trick seemed to only temporarily work for me. The transformer and frequency selector plate is missing. Could this possibly cause the fast speed? (56)Not much on there is there? Just that one board that I can see. Funny. Take a look at the service advisory. Probably the belt. I remember trying three belts before I found the right one for one I had. Now I have 6 or 7 belts of different sizes I can try. Left over from past mistakes. I recommend you clean and lube the capstan shaft and the platter receptacle. Be very careful not to get any lube on the belt, platter, or the capstan in the belt path.
I double checked the service manual: I think there’s an adjustment screw for the belt guide. Will try adjusting tonight.I don't see how a missing cover could affect the motor speed. There aren't that many options here. The motor, the belt, and the capstan. Unless your platter is not original. Check the platter to see if there are any identifying marks on it, and while you are there, I would clean the inside of the platter where the belt rides.
Sorry for the late response. I tested it, speed is less than 2% off. It’s actually a tiny bit slow now! But I didn’t spend too much time adjusting it however, just wanted to see if it made a difference. Not sure if moving the plate under the screw helped or the wider belt, but we’re on the right track. I think I’ve got it from here, thanks everyone! Who knew an extra ten minutes of work and a year of thinking it over would result in a fixI double checked the service manual: I think there’s an adjustment screw for the belt guide. Will try adjusting tonight.
correct frequency is essential for speed of electromotors in this era! Also the correct or incorrect in your case, used for 50hz or ment for 60 hz capstan.You are one hundred percent correct. I’ve decided to return to this turntable again, hoping to make some progress. The grommet spacer trick seemed to only temporarily work for me. The transformer and frequency selector plate is missing. Could this possibly cause the fast speed? (56)
I double checked the label on this turntable, 100% meant for 60 hz. So maybe the transformer wasn’t needed due to this? Or possibly was removed prior to when I purchased it locally. Who knows, but surprisingly the fatter belt with adjustments of the belt guide position resolved this. Hoping to get the speed even closer to 33.3 rpm soon, fingers crossed.correct frequency is essential for speed of electromotors in this era! Also the correct or incorrect in your case, used for 50hz or ment for 60 hz capstan.
