Sansui SR 929 with ADC 2 and Supex cart
O au-d11mK2
Member
thoughts on the styli? I think the ADC is the 2 with the removable head (thus not as optimal as the 1?)
Looking to by the turntable to go with either my AU 9500 or my AU-D11mkII
Any and all input welcome.
Welcome to the AK turn table forum
The styli on the Supex Mc cartridge looks OK from the picture.
The Supex Mc appears to be a lomc - low out put moving coil cartridge, assuming that it is
You can use the Supex Mc with moving coil cartridge phono in put on the Sansui AU-D11.
There does not appear to be a moving coil phono input on the Sansui AU-D9500.
You can not use only the mm cartridge input alone, you will need an additional SUT .
The ADC heashell will not work with the Sansui SR-929 tone arm. :no:
Best of luck with your vinyl venture . :music:
