Power consumption will depend on how loud you will run the amp. None of these is class A or a power plant, so they will not suck much power at low volume. The Technics might have higher consumption than others, the NAD will probably have the lowest consumption.
If the price on all these is the same or similar, go with NAD Model 60. It is a very good early NAD amp, assembled to NAD specs by Foster Electric I think). It is also very rare and holds its value. The one I had actually doubled its value in 2 or 3 years. And it is one of few NADs that look really good. It might need more servicing then the Sansui - it is about 5-7 years older and uses transistors that tend to go bad. Mine had a bad transistor in the phono section and produced all kinds of noises. Replacements are available and dirt cheap though.
Don't expect the NAD "house sound"/"British sound", this amp looks and sounds like a Japanese amp, because it is one.
If Sansui is much cheaper, you can consider it. It might actually sound a bit better (cleaner) than NAD, depending on NAD's condition, and it has more power (almost 2x more), but will have a problem with some speakers (will sometimes go into protection on 4 ohm speakers). NAD will not. Also, it does not look as good as the NAD and it is not a collector item.
Forget the Technics. Not a bad looking amp, and not bad for Technics, but can't compete with the other two.
Cheers,
Raf
