I posted this on Facebook as well. Any assist would be appreciated!
I have a TU-717 that is original and performs rather well. Two issues I'd like to address.
First is the station pointer, it is off by about 0.3. I see the pointer is "glued?" to the string. Do you need to remove the glue and slide the indicator into proper position or is there another method to correct? (see photo). Where can I get instructions? Didn't find in Service Manual.
Second, the signal strength meter only gets to about 3 and a bit. Have a good antenna and other tuners register higher signal strength. Is this a full alignment issue or another tweak I can do?
Thanks!
Thanks!
