Sansui TU 9500 antenna
johnnyboy70
I just got a Sansui TU 9500 to go along with my AU 9500. Do any of you know if I need to buy an antenna to go along with it? I tried Hi Fi engine and only found a brochure. Going to hook it up after I get over this damn cold
I expect you'll need an FM antenna. The built-in AM antenna should suffice for AM, but FM usually needs at least a twin-lead dipole, the dual-wire ribbon 'T' that connects directly to the tuner. I use a Terk FM antenna (non-powered) and it works extremely well. Depending on how close you are to the signals you want to pick up, you might consider getting a powered (amplified) antenna. Lots of possibilities online.
Thank you LWB! Will do some research. If anything Radio Shack is down the street
