SANSUI vintage
y2khunt
I have just bought a SANSUI qs500 rear quad amp.thst i am doing somthing wrong or unit is bad.I get meters work to the musio but no sound no nothing hum or anything.I might have ut connected wrong,kinda crazy he said it worked a year ago but has no idea on hooking it up.any help would be great.
New member
@y2khunt
Welcome to AK! and here's hoping whatever is acting up on your amp can be rectified with suggestions from fellow AK'er's
Just a suggestion help us help you, before you post reread what it is you're posting and ask yourself does this make sense.
What you posted earlier is really hard to understand.
In the meantime you might find this helpful
https://www.vintageshifi.com/repertoire-pdf/pdf/telecharge.php?pdf=Sansui-QS-500-Brochure.pdf
Operation manual here (free)
https://www.hifiengine.com/manual_library/sansui/qs-500.shtml
Often a reason for no sound, check position of tape monitor switch. It needs to be OFF.
New member
Do you have quad records or tapes and a quad turntable/cartridge or quad tape deck? If not, you won't be hearing quad reproduction.
Plenty of info in these threads
https://www.google.com/search?q=SAN...HchFDKsQrQIoBHoECCUQBQ&biw=1600&bih=757&dpr=1
Download the manual from HiFiEngine. It will show you how to hook it up. Remember, this is for the rear channels. You need to have a front channel amp and you have to hook it up correctly to it. Good luck! This is a very cool find!
And welcome to AK!
