Sansui ZR-1000 --> Cap Replacement?
Replace the capacitors?
  • Total voters
    2
audiophilico
So I just cleaned and lubed my new very good condition Sansui RZ-1000 yesterday and WOW! My mid-grade Polks and Circa 1980 pristine 3-way 12" Technics were pumpin! Of course the bass was waay high but the amp put out more power than both my ailing Denons 1909 and 4800.
It wasnt really on my mind to do the capacitors because Im just learning this stuff, but given some time to mull it over Im thinking of swapping the capacitors out and really seeing what this things can do given what the pot and contacts job did. Should I go for it? Is it worth the extra bucks? Will it make that big of a difference?
Thanks!!
It won't sound better after recapping. Unless one of them is already busted. Given its age I would expect the caps to hold out for quite a few years to go. No need to just replace them all now.
If you want to practice a bit of recapping: just find yourself a step-in model ampy from the early 70's. That one will probably sound much better after a recap, and be in need of it by definition.
