Hello,
I acquired a sanyo rd 1400 cassette deck for $5.00. However, it will not play, rewind, nor fast forward a cassette tape. When you press the play button, it makes a grinding noise and starts to play and the LCD display right and left channel move for a split second, but it immediately stops playing the tape. The same thing happens if you press the rewind or fast forward button. I am thinking that this might be a belt problem? Thus, I am not able to play any tape, rewind nor fastforward. For the moment, it makes a good decoration!
Now, I know this isn't a high end deck, but I would like to see if I can fix it before tossing it out. Do you think that the belts are bad? It is from 1983.
Thanks much for any advice.
