Sanyo dcx-4000ka receiver quad ?
6mantoys
Well-Known Member
Picked this thing up a while back.Cant find any info on it.It has a 4ch sp/mtx is that a type of quad thing.Another nifty option is the preout/main in feature.P7170036.jpg
To your query re:4ch, this is a stereo amp. Any connections for the matrix/4ch involves speaker connections as there are only 2 amplified channels inside.
Cheers,
David
From a SANYO flyer.
DCX 4000K Stereo Receiver
Features pure complimentary circuits with PNP/ NPN transistors
IF amp in the FM employs high performance IC's and ceramic filters
Also 2 separate monitor switches, FM/AUDIO muting and mike mixing
Continuous power: 26W+ 26W, 1 KHz, 4 ohms, each channel driven
Dimensions: 18" x 13-5/16" x 5-13/16"
Weight: 20 Ibs. 8 ozs.
Michael-Otto
Plus I hope you have the PREOUT/MAIN IN JUMPERS, or else you won't have 2 channels, much less 4.
Larry
Have all the fuse covers and the jumpers.It is in need of repair as the preamp only has one channel.Amp works great.I was wonering about the quad thing as there is a speaker selection for 4 ch sp/matrix.
