dinger
So I have a NAD C427 tuner that uses this chip. The tuner has no signal meter but some data sheet research reveals this chip does have a signal strength output. (0 to 0.2V)
I assume the tuner is only using this to select when to pause a scan or when to kick in mono blending. What are the chances I could tap into this for actual signal strength monitoring? I've scouted out both analog and powered digital voltmeters suitable for the task. I can make the connections no problem. I guess my concern is loading the circuit too much or this is just a silly idea.
