Bump..... Still in need of this schematic. I re-installed the multi-cap on my unit tonight, along with installing a new AC cord. I actually made a change from the way the unit came apart. In my unit, the OT Center Taps, Output Tube Grids, and the first stage of the PS filter cap (60uf) were all attached directly to the rectifier output. I noted that on the 'C' version of this amp they used a 33 ohm / 7 watt resistor to connect from the rectifier to the first stage PS filter....and had the OTs and Grids attached to the cap after the resistor. I had a nice Dale 39 ohm / 10 watt resistor......so I'm using it from the rectifier to stage 1. While I had the multi-cap out, I ran it on my Tel-O-Mike Cap tester.....and more or less 're-formed' it while out. It's in really good shape....with really low leakage. So, hopefully it's good in the amp. It's back in for now anyway. There's one other multi-cap that I am forming now. I have the amp on a variac at about 50 VAC and I'm seeing about 110 VDC at stage one of the PS filter. I REALLY need the schematic.....or, if not that, at least the early unit bias setting procedure. I only have one pot on my unit, and there's a 22 ohm resistor to ground that also has the test point attached to it. I assume that's the bias set test point.....but what' method' to use I'm unsure of. Maybe I just set it until I read .35 volts on it? Dunno........ Help needed!!! WC
