yea missed that. 470K I could believe though.
the 100uF next to the screen reg is sort of extra too now that I'm looking at that part of the supply. Its in parallel with the series 220uF caps. Makes for effectively 210uF, which is fine, but its a 500v cap in parallel with effectively a 700v cap. Can't hit that with more than 500v safely, and that sort of defeats the purpose of having the two in series to get a 700v cap. Not going to hurt anything but you could just get the same thing done with a single 220uF 500v cap.
something else I just noticed, the coupling cap to the inverter is at a tap point of two 30K resistors in series that make up the plate resistor on the input tube. Thats going to throw away 50% of the signal available at that first tube. Not really a good reason to do that.
