SoNic67
Well-Known Member
I have this 3 foot cable:
https://www.amazon.com/gp/product/B00GZQWLF0/
Really? Well it has a power switch for one thing, and secondly, they don't mention that in the manual.Actually the MiMBy is supposed to be left on at all times.
It doesn't consume much power, but it does get warm. This takes it's toll over time on electronic components. If your not using it for a extended period of time, IMHO it would make sense to turn it of.
Sure as mentioned to each his own.Mine stays on 24/7. Going to Hawaii for a couple weeks next month and I'll shut down everything then including the Raspberry Pi3. ..
That is pretty much what I said. I don't know about failing solder joints, or heat caused premature component failure, and if it does fail someday It would likely be many years and will likely want to upgrade anyway. My first DAC, the original Modi has no switch. It was on until I unplugged the usb cord, which I did faithfully for a while until I came to the conclusion that I was going to wear out the usb connection point. I am still using the original Modi for direct sound from my Windows machine, and the multibit stays plugged into the Raspberry Pi3 for all music I listen to from my library. Now they all stay on.Sure as mentioned to each his own.
As it should be.
Where I disagreed was that Schiit designed it to be left on all the time. Or Schiit recommends that as Hofy stated.
I don't see any evidence that supports that.
Nor any evidence that supports turning things on and off causes the acceleration of solder joint failure.
If the Modi doesn't run hot enough to cause component failure well I would think it doesn't run hot enough to cause solder joint failure if this is the case.
Maybe just say I like leaving mine on 24 seven and leave it at that...
You beat me to the switch location theory. I leave my Gungbir MB on 24/7 as well. along with the Linn Kairn pre, and Goldmund Memisis 6 power amp. The Goldmund has been on for more than 20 years with no problems.I use a Bifrost MB, and it definitely sounds better when its been on a couple of hours. I just leave it on all the time, unless I power everything down to leave town or make system changes. I think that by having the power switch (toggle) on the back of the box they are "suggesting" that you just leave it on as it's not all that easy to reach the switch. I doubt that it hurts anything to turn it off when not in use, but I really don't think you get the best sonics that the unit has to offer until its good and warm.
