Scored a cool GE RC-1671 console w/ Garrard Autoslim TT. What now?
Jimuh
I got this cool GE console w/ Garrard TT for $20 at an estate sale. It's nice and well-kept, and mostly in working order. Especially nice for playing 78s with the special stylus! Only problems are finicky speed selector and broken 45 changer spindle. I've replaced the latter. Wondering what you all would suggest for upkeep and maintenance tips to get it in best possible playing condition?
Thanks!
Canned answer for all record changer problems is to clean out all of the old grease and replace it. Garrards in particular tend to get very gummy with age and things just don't move correctly anymore. The Autoslim family is fairly easy to work on, its just a lot of linkages to keep track of. Take a lot of pictures, it helps. Most of the time the grease will wipe off with some mild solvent. I've used alcohol but mineral spirits or kerosene also works well, it just smells bad. Any light grease will serve as a replacement. i usually use silicone grease because I have it but lithium is also fine. Very small amounts only. Where it calls for oil, sewing machine oil or 3 in 1 electric motor oil works fine. So will hydraulic oil or any other lightweight non-detergent oil you may have on hand. Mostly its the platter bearing and motor that want the oil, the linkages generally get light grease or nothing at all.
Thanks!
You may want to look into how to determine if the capacitors (especially the electrolytics in the power supply, and any signal path coupling caps) have survived the years since they were built. Capacitors don't live forever, and things can get ugly if they fail...
Thanks. I'll take it in to my local shop. By "things can get ugly," do you mean that the unit can overheat and catch fire? Would replacing the old capacitors make it much safer?
Replacing capacitors can extend your listing experience by keeping the magic smoke in where it belongs. Bad capacitors can cause burning out of tubes and transformers that may be hard to replace due to money and availability.
Thanks! The interwebs tell me that this unit has 3 capacitors in a paper tube (see image). Any idea what it might cost in USD/parts & labor to replace them? I'm taking it in to the vintage audio repair shop this week, and would like to know approximately what I'm looking at.
Take it to your tech. Pricing will vary depending upon the tech and your location and the present tariff situtation.
I do my own repairz.
