Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
The move to the new server is done. There are some software and database maintenance updates in process. This has us passing the hat around to help out. We appreciate any donations. Seriously, even a dollar helps. The payment page may be found here - https://www.audiokarma.org/support.html
Quit good actually. They replaced my Minimus 7's and are paired with a RS sub made to work with the minimus 7's. Is my office setup and gets a lot of use. Good sound.
Don't know about your CG12T, but my CG10T's Qts measured a bit higher than what I found online. Mine would work OK on OB I guess, although I'd like even higher Qts for that. I guess it should be easy enough for you to try them on OB's. Just keep the volume low as not to bottom them out.
