Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
The move to the new server is done. There are some software and database maintenance updates in process. This has us passing the hat around to help out. We appreciate any donations. Seriously, even a dollar helps. The payment page may be found here - https://www.audiokarma.org/support.html
You use LH. This is a higher bias tape than the brown oxides. Your RT-707 is biased for this formula from the factory. It was one of the better tape formulas made when this Pioneer was new.
Well, I tried recording in LH, and it sounded like someone put a blanket over the speakers. Switched to std, and the highs came back.
All my other tapes indicate they're high-output/extended range, and they sound great on LH. But this one didn't say that on the packaging, and a few test recordings showed std bias sounded better. So, that's what I used.
There is an owner's manual on the AK Database if you lost yours. I think the Scotch 206/207 settings were one was normal/one LH. That owner's manual gave your the settings for given tapes when the machine was built. So, since Std sounds better to your ears, use that. Those were not set in stone, just guidelines.
