scott 350R reciever
turbolite81
pioneer & vega nut
i have a scott 350R reciever that im refurbishing for a family member.i am unshure of the date of manufacture or the output, info on this rig seems hard to come by. i am trying to find schematics/capasitor part #s for it. if there are any known mods it would also be much appreciated.:scratch2:
thanks rygen. i got the links on another post i started for this unit under tuners,,, still no luck, even at the sites i cant find a 350r. i guess ill just read all the caps and convert them to the latest thing, i dont think ill have any other options?:scratch2:
does anyone know a good replacement # and source for the 8200uf 50v main caps for this unit? i have found a few options from newark supply but wonder if they are correct. the diminsions are way smaller than the originals???
when i fire this unit up,the signal meter pegs out and the tuning meter shoots to half way negative? the am works, all aux circuits work, but no fm! any ideas out there???? i have checked the board for obvious shorts and have found none. i did a full de oxit cleaning and replaced all electrolitic caps per manufacture specs. i double checked all cap polaritys also:sigh:
I know it's an oooold thread...
...but I just picked one of these up from original owner. One bulb out, but it came with original operator's manual. Anybody want a scan let me know. Put it with some Infinity SM150s. With loudness on you can drive worms to the surface outside. Too boomy for my liking, but I had my 15 year-old laughing out loud with all the bass.
Chaad,
Please Scan the OM and follow the directions in the link below for the benefit of all the AK'ers.
http://www.audiokarma.org/forums/showthread.php?t=349095
Thanks & good luck with your 350R!
Please post the manual to AK database.
I will have my newly acquired 350R delivered tomorrow (hopefully in one piece).
Another request for you to make the manual available.
I got one of these several years back and shortly after it developed a problem where upon powering it up, the lights would flicker and the audio would stutter. First thought was a power supply issue or the on/off switch. It's been out of commission ever since.
I found service manual on-line and will upload it this weekend. chaad, please upload owners manual. This will make the 350R documentation complete.
drabina, I hope it is OK to send you na message regarding your thread concerning the Scott 350R. I was seeking info for the Scott 350r receiver and found your comment about a manual. Can you lead me to the place where i can get a manual,diagrams or schematics. I would be extremely grateful.Email is 65ponyrider@gmail.com Thanks in advance, Paul
Funny, mine has done that since I got it 3 years ago. My solution is to just leave it on; it's be in constant use in my office since I got it with no problems.
One of these days I should try to figure out what the issue is.
Edit: I just checked and I have the service manual. I've submitted it to the AK database.
Lights on and flicker nearly always is bad ac switch. Search pioneer and kenwood forums, as well as here for switch repair. There is a recent thread in the Kenwood forum with pictures of the same kind of switch for kr-4070. Good luck.
So I am repairing the power switch on my recently acquired Scott 250R (NOT a 250RL). I have already cleaned up and polished the contacts which were badly burned and causing "flickering" pilot lights (both sets were bad). But to prevent burning up the contacts again, I am going to install a relay between the switch and the transformer (see photo below - not completed). This way, the current through the original contacts will be very small (about 50ma) which will give them a very long life. This works great, especially for high power receivers with heavy current flow through the power transformer primary.
After tracing the power switch wiring, I discovered that while there is a wire connected directly to one side of the power cord, there is no wire from the other leg of the power cord in the area of the switch. This means I will need to run a separate wire from the other leg over to the switch (not a big deal). And that also means either adding another fuse, or running without a fuse in series with the relay coil. I may just run the relay without a fuse....
Anyway, I found a "Service Manual" for a "250R/RL" online: https://drive.google.com/file/d/1Vv3NoTLgajIzOSMhsv_DZyq-K9Y0i1CH/view?usp=sharing
However the schematics in this service manual are not correct. The power switch wiring is not the same as shown in the schematic. The schematic shows both sides of the power transformer primary switched by a DTST switch connected to the power/speaker selector. However, my unit has only a single switch on one leg of the PT primary (with a fuse between the switch the the primary).
Note: Others have noted that there is a "spare" contact in the switch body and that you can simply rotate the switch to use the other set. And this was true for my 350R. But now that I'm looking at the schematic below, the dual set of contacts in the switch makes more sense. I suggest that they are not spares at all, and that Scott simply decided not to use both sets of contacts to save assembly costs.
Also, the schematic shows as 3-wire AC connector, but my unit has a 2-wire cord
. There are other differences as well. So what gives?
I can still figure out how to add my relay, but I'd like to have an accurate schematic for the "350R".
Has anyone seen a schematic that matches your 350R? If so, can you post it or send it to me?
Thanks!
More photos of switch contact repair: https://photos.app.goo.gl/tSw1kMfee2yoLeoA9
