Scott LK-48b Electrolytic Capacitors
jcon109
I am looking at getting electrolytic capacitors from Hayseed for my Scott LK-48b. They have a prebuilt kit of 3 for a 222d which are the same values as mine on the schematic but the Hayseed value for voltage on one of them is 450 volts instead of 475 volts listed on the schematic. Is this an issue or will I be ok to use?
Thanks
Always go with the voltage that is engraved on the capacitors. For replacements, you can always go higher but never lower on rated voltages.
UPDATE
That is what I though too so I emailed Hayseed and they realized the mistake and have corrected the voltage values to 500. What a great company to work with!
Jim
